Old S7-300 SLC code - what's going on ??
Holmux
Oct 2013
Aalborg
279
HI
My SLC understanding is not perfect yet, and have been over the manuals again and again, but I am digging true some old code and I have this little section that I am not totally sure about:
L DBW 5
SLW 3
LAR1
L DBW [AR1,P#0.0]
T MW 5
Does this make sense to anyone ? :unsure:
If we for example say the value of DBW 5 = 2
How would this workout ?
/Holmux
Hello ,
The code is not complete, but I will try to explain the meaning.
Code:
L DBW 5                  // Load the value of db? .dbw5 opened before.
SLW 3                    // Shift it left by 3. If for you the value of dbw5 is 2 the risult is 2 slw3 = 16 decimal
LAR1                     // Load the result into the register AR1 like address.In our case is 2.0
L DBW [AR1,P#0.0]        // Load the value of db?.dbw2.0
T MW 5                   // Trasfert it to merker word 5
Siemens indirect addressing
1. load value from DBxx.DBW5 ()Is there earlier command OPN DBxx? on code)
2. SHL 3 (SHIFT LEFT 3 -> INT to pointer format conversion, same as multiple with 8, pointer has 8bits and word address -> so now we look word address. ex. DBW5 = 2 -> SHL 3 -> 16 (Pointer points to second word, if you don't SHL3/multiple8 then pointer points to 2nd bit...)
3. Load pointer to AR1
4. Load from DBW address with pointer , P#0.0 is offset (ex. AR1 =16 + offset 0.0 => Load pointer = 16 (points 2nd word)-> load DBW2)
5. transfer loaded value to MW5
same if DBW5 has value 3 or 4, now we load indirectly 3rd and 4rd word to MW5
Thanks for the help
I have been searching high and low for some more detailed information on the "Offset" function, but reading the Siemens help file convinced me that they drink a lot of beer in Germany, very confusing :)
To be honest I don't have a clear view of the basic's of the Offset function, :( I remember reading a good article about the function way back, but can't seem to find it again.
Can you point me in the right direction ?
/Holmux
Hi, I have a few questions in relation to a new project I must design. Sorry if a little vague on existing hardware, but it's all the information...
14,030
This is one for the siemens crowd. We want to replace a S5 95U connected to 3 banks of I/O I am not kidding when I say lots of I/O. All I/O are 8...
3,115
is it possible to get the old type s7-300 cpu download password? I know we can get password from the mmc card, but the old cpu(6es73152af03...)...
1,652
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
140
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
236
