Red Lion G310C2 Extract problem
nozynoz
May 2013
Bolton
Hi all.
Thank you in advance.
Been fighting with this new HMI Red Lion G310-C2.
We bought a spare and need to download the database for safe keeping and some modification to code and then upload.
Problem is unable to download (extract) the from the unit.
Methods used
Updated Crimson versions 2 and 3, software to the latest versions
Checked configurations all seem to be fine
USB
USB cable and checked if drivers are installed correctly, yes.
On extraction error
Error - the device dose not contain an uploadable image
NETWORK
Tried through network failed.
Able to Ping and get a response
opened using browser, it works
checked the setting on crimson, all settings correct.
On extraction still get error
Error - the device dose not contain an uploadable image.
Can anyone help or point me to in the right direction.
Cheers
Nozy
The Error describes your problem.
Whoever downloaded to the panel did not have "support upload" checked when they downloaded to the HMI.
You need to take the original or any .cd3 file you wnat to run and re-download.
If you want someone behind you to be able to upload you need to make sure it is checked.
Link -> Support Upload
Hi all.
Methods used
USB
On extraction error
NETWORK
Cheers
Nozy
Download = send to HMI
Upload = Extract = get from HMI
This is how Redlion (and in my experience most systems) describes the functions.
I agree with the previous post that states that the download was done without the Menu Item Link -> Support Upload checked. You will need the original configuration file.
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
268
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
279
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
110
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
223
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
114
