FactoryTalkSE User account Logout and Auto login to Other account
minaykha
Apr 2009
singapore
96
I am using Factory talk SE Version 8 , local application.
I created 3 user accounts in application,
User 1. Viewer ( Only for Overview Display page)
User 2. Operator ( Only for Overview Display and Operator Display page )
USer 3. Engineer ( For all displays page )
Anybody can advise how can i get the feature that when logout "Engineer" account, then auto login as " Viewer " account??
Now in my current application, When i press logout button, popup login/logout message box come out every time.
Thank for your help.
Just make your "logout" button a "login" button for the new user. Off the top of my head I think the syntax is as simple as "Login <username> <password>". You don't have to log out the existing user before you can log a new one in
Hi ASF ,
Thank for your reply.
I created new user name and password.
User Name : Viewer
Password : Viewer
I create button property as you mentioned(Press action : "Login<Viewer><Viewer>"), but it can't auto login as user "Viewer".
Any idea ? thank.
The syntax looks correct - what does the diagnostic window say when that command is ran?
I always create a local DEFAULT user with the password also as DEFAULT and login with that user.
I never do a "logout" only "LOGIN DEFAULT DEFAULT"
minaykha
Create a macro called for example "Log".
Type command:
"Login Viewer viewer"
Syntax for this is: Login Username Password.
This command auto-logout current user and log user that you put in macro.
Create a button on your display a put in "release action": Log.
It run your macro with auto logout and login.
Dear All,
Thank you for your help and attention.
I mistakenly put bracket in button press action, login <Viewer><Viewer> ,system can't understand it because of bracket <>.
Now, i corrected button press action as, login Viewer Viewer
Then, Viewer account can auto login when i press the button.
Thank a lot !
Sorry! Yes, I probably caused that confusion in my original post, I just put them in there to differentiate between the command and the user-specific information.
Glad we could help, and thanks for reporting back (y)
Been working on this Conversion and wondered how to go about the following Networking Issues. scenario: Two computers 1 is running FactorytalkSE...
1,062
Hello everybody, My hard disk was crashed and i changed to a new one ..reinstalled win7 32 bit ultimate factorytalk rslogix5000 and softlogix. I...
1,464
Hello all! I'm trying to get a "Previous/ Next Graphic" tool set up in the corners of the graphics to enable users to return to a previous...
1,146
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
161
Hi guys! I'm working in Studio 5000 and have a bunch of armorstarts there (+- 40). I need to set up parameters for each of them, mostly just same...
94
