reports in vijeo citect 7.4
Lots of people can probably help you but your question is so vague, in its simplest terms the answer is by writing them !!
A few questions to consider for instance, how many bits of data, how historical does it need to be, how do you want the report presenting, PDF, Excel, text file etc. How is the report run, from a button in Citect, from a web browser etc. etc.
You can generate reports fairly easily using the standard Citect reports and events, have you read the manual ? If you need rich reports with lots of data and charts then you may need to look at the dedicated reports package.
Have a look at the standard functionality and come back with questions after that and i may be able to help a little
Cheers
Cheers
@tragically1969
thank you for replay, but my Question not so vague , i want the solution in general
i read the manual carefully and try to apply this on .rtf as a simple format but the report does not generated automatically
regards
how to make monthly report contains table of same variable every day for example 1 Aug. ...... 2 Aug. ....... 3Aug. ....... and so on till 31 Aug.
1,130
i have Vijeo Citect Historian Server Here in Historian Server we have tab Historise to logg data.. How to retrive the logged data in excel client...
2,010
Hello Everyone, I am working on reports in Vijeo Citect V7.40. I want to generate a report whenever I press the button. I am able to generate it...
881
Any advice on below issue? ➢ IFix 5.0 with USB Hardware Dongle License Standalone application connected to RX3i PLC units via Ethernet (bridged...
1,631
Hello Guys, I spent some time searching the web to learn how to generate the report (to be printed out or to be saved as pdf file) which would...
1,213
