Creating recipe with Wincc Flexible 2008 SP3
JEANST
Jun 2015
PARIS
68
Hello
I'm looking for a way to do the following but i don't know if it's possible..
I use Wincc flexible runtime PC
i use the recipes as follows
1 recipe (recipe name = Customer name)
parameters for each recipe(customer) => param 1, param2, ...
datarecords = list of the products reference for the concerning customer
I would like to know if it is possible to create a new recipe (new Customer) directly from the runtime application to enable operators to create new customers when necessary. by VBScript functions or other way.
usually i create the new recipe directly in winccflexible but they will not in the future.
I read many things on create/copy/delete datarecords from 1 recipe but nothing on create the whole recipe
Any help would be greatly appreciated :)
Hey
Hello,
I have done something like this.
In VBScript I used Export Recipes and Import Recipes from CSV files. The CSV files are exported in VBSCRIPT because I used the customername in de CSV filenames. With an Import button I could import the exported CSV files. 1 customer.csv file is a complete recipe. The records in it are the orders.
I can give you the vb script =>
Export:
Code:
Dim fso
If SmartTags("Databasename") <> "" Then
Set fso = CreateObject("Scripting.FileSystemObject")
SmartTags("File") = SmartTags("Databasename") & ".csv"
ExportDataRecords "Order Database", 0, "C:\S\ORDERS\" & SmartTags("File"), hmiOverwriteWithConfirmation, hmiOn, Null
End If
Import:
Code:
DeleteDataRecord "Order Database", 0, hmiOff, hmiOn, Null
Delay(2) '2 seconds delay
ImportDataRecords "C:\S\ORDERS\" & SmartTags("File"), 0, hmiOverwriteAlways, hmiOn, Null
LoadDataRecord "Order Database", 1, Null
SetDataRecordTagsToPLC "Order Database", Null
ResetBit SmartTags("BATCH STATUS.VERZENDEN")
Hello
Interesting POST... maybe you can help me!!
Hello!
I'have to do something like you described in first post...
I have to manage recipe via VB Script... is it possibile?
In particular I have to:
1 - import complete recipe list via .csv file
2 - create new recipe via VBScript
3 - change recipe name and elements via VB Script
Is it possible?
Thank you!
Project example
Hello,
Export:
Code:
Dim fso
End If
Import:
Code:
Dear Combo,
Can you give me this example project with VB code to me please
[email protected]
Thank you
Vorapob
Hello I'm looking for a way to do the following but i don't know if it's possible.. I use Wincc TIA V15 comfort panel i use the recipes as...
3,592
Does any one have a sample code for creating recipe in RSLogix 5000. I need to be able to save 20 recipes that could have up to 20 ingredients...
2,389
Good afternoon, I need to create a recipes display on the hmi ns8, to change the parameters of a servo and some strings . The PLC that im using is...
2,775
The idea here is to provide for a brief rapid influx of message codes while preventing sequentially repeating the same message. i.e. if two...
23
710
Hello everyone, In a factory where we installed Citect 7.20 the computer began to show the first signs of end of life. They never considered...
84
