WinnCC flex 2008 - Trend View log time
krisrae91
Apr 2015
Crawcrook
I have just set up a trend view graph which monitors two temperatures. The log time will only let me view results as far back as 8 hours. Any ideas on how to extend the log time?
Cheers
If I remember correctly, for the trend view object WinCC Flex 2008 trends display a user defined number of records/values. If you wish to change the amount of data displayed you will need to increase the trend values(TIA calls it trend values, I think its the same in WinCC flex) accordingly.
Time required / sample time = number of trend values required.
For a realtime trend view, you can have 900 (or is it 999 ?) values to display.
So for 8 hours, the cycle trigger must be set to (3600 sec/h x 8 h) / 900 = 32 sec.
If you want to look further back in time, the cycle trigger must be increased accordingly.
I do this, by having several trend views for the same variables for 1 h and 4 h respectively.
That said, for trending values far back in time you really need to use archived tag values. It costs an archives license.
I've created a faceplate in WinCC flex 2008. I've written a script in it. I can run this script if I put a button in the faceplate that calls the...
4,000
Hi everyone, i make a programm in WinnCc Flexible, and i have a question, i explain what i want to do: i have 6 buttons. when i press one of...
1,375
Hi, I have added an OPC client to an existing WinCC Flex project. Although I can see all the variables from the OPC Server it won't let me...
2,020
I'm new using Wincc FLEX and I would like to know how make a start button change it's color to green when staus changes from 0 to 1. I'm using an...
1,615
Is there a way to globally replace addresses on a Screen? I can't see a way to export the screen to modify in word, excel etc. I also can't see a...
1,471
