motors
medensat
Jul 2015
CASABLANCA
19
Hi guys,
i'm working in a project of a Mitsubishi PLC (FX) , i want to make a program ladder that controls two independent motors one at a time, the standby motor automatically starts in case of failure (coupur energy, default) the first engine.
i program with gx iec developer 7.04, the 2 motors are switch on by (enable1,enable2).
Thanks in advance
OK, this easy to do so what's the specific problem you have ?
Search this site for duty standby, there will be plenty of examples
I need a program,i want to make it so that if the main motor is running and the temperature sensor reaches (1 or 8 C°) the opposite motor will start automatically and the original motor will shut down . Both motors can never run at the same time.
inputs: Enable1,Enable2,sensor.
outputs:2 motors.
note: don't worry about the sensor you can consider it as an ordinary input what interests me is how to make the switching of two motors
outputs:2 motors.
Nobody will write the program for you, they may if you want to pay some $.
Its pretty simple, you have described what you need it to do now translate that into PLC code in ladder.
Did you search the site for Duty/Standby control of motors like I said, its been covered many times before
What have you written so far ?
Dear colleagues, hope you can help on that matter. We have a project where we need to control 3 servomotors to move a auger feeder system...
38
1,181
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
230
In a control System, I need to move 3 motors attached to roller in stages with speed of 1 to 2 RPM and the torque of motor should be 8-10 Nm...
832
I'm working on a design phase for a costumer and they've requested PM motors for all conveyor belts throughout the system. We have a gapping...
529
Hi guys, I have a problem with setting up the parameters for PowerFlex 525. So we have 4x motor connected in parallel to 1 PowerFlex, each motor...
1,093
