E300 Programmable Settings
Joshua37
Aug 2014
Dallas
47
Hello folks,
I'm using a AB E300 Overload Relay for a few motors that I'm suppose to integrate with my CLX-L71. I've been able to successfully configure, communicate and create the tag database in RSLogix 5000 using the AOP.
The trouble scoop is the flexibility in trip settings(or I haven't figured it out)-
The overload algorithm of the relay trips the motor based on the parameter 'PercentTCU' which ranges between 0-100%(fixed). The two parameters affecting its value are FLA(Full Load Ampere) and TripClass [as shown in fig.] which are programmable as per the user manual.
The issue that I am facing is that I am not able to run the motor above 100% load if needed as I can't change the PercentTCU limit as the trip limit is set to 100%. FLA and TripClass are programmable but need a download every time a change in load percent is needed either in the module property or the tags.
Is it possible to change the FLA values while online or to change the PercentTCU Limit ?? Or Am I missing something ??
Hello folks,
TCU stands for Thermal Capacity Used, so when you have used 100% of the thermal CAPACITY of the motor, it trips, because... there is no more than 100%!
So that does NOT mean 100% of the RATING of the motor, that is different.
Thanks.
And yes, I get the fact that TCU Percent can not be greater than 100. But I want to know if can control it with the Motor FLA value without downloading the program everytime.
Hi, I'm using E300 as E3 Plus in emulation mode. E300 is Rockwell Automation's overload relay. But I get hardware fault when I enable Ground...
495
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,068
Hi everyone, I have So many E300 Control module kept dead due to Module status fault. I am trying to flash them to higher version from lower...
415
Hello, How do I go about adding an e300 to a motor greater than 200A. I have no problem adding it to any other motor less than that. Thanks!
1,132
Hello everyone. I have a bunch of e300s connected to a startix which is then going to the plc. All of them are showing their MS and NS lights...
4,783
