RSLinx OPC Read with VB.NET Extremely Slow
Archie
May 2002
Orangeburg, SC
1,944
I was working on some bench mark tests for different drivers and once I got to RSLinx I am getting a really slow read time. It is taking over 2 seconds to read 100 DINT tags from a CompactLogix. Compare this to a range of 45-75ms for other drivers.
What I am wondering is whether I am not performing the read in the most efficient way. My objective is to synchronously read 100 DINT tags. (Actually 1000, but RSLinx does not seem to read more than 120)
Here is the way I am reading the values:
Open the connection on application start:
Code:
    Private OPCServ As Opc.Da.Server
    Private fact As New OpcCom.Factory
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        '* Connect to the OPC Server
        OPCServ = New Opc.Da.Server(fact, Nothing)
        OPCServ.Url = New Opc.URL("opcda://localhost/RSLinx OPC Server")
        OPCServ.Connect()
    End Sub
Perform the read on a button click:
Code:
    Private Sub ReadButton_Click(sender As Object, e As EventArgs) Handles ReadButton.Click
        '* Create the item array to read
        Dim items(0) As Opc.Da.Item
        items(0) = New Opc.Da.Item
        items(0).ItemName = "[IOTest]DINTArray,L100"
        '* Start the stopwatch to time the duration
        Dim sw As New Stopwatch
        sw.Start()
        '* Synchronously Read the values
        Dim values() As Opc.Da.ItemValue = OPCServ.Read(items)
        '* Stop the timer
        sw.Stop()
        '* Report the result
        If values(0).Quality = Opc.Da.Quality.Good Then
            MsgBox("Read time=" & sw.ElapsedMilliseconds & " ms")
        Else
            MsgBox("Read Failed")
        End If
    End Sub
I did figure out something with this. I created a subscription to another variable and that made the synchronous reads drop down to about 200ms. Apparently the first read goes through a lot of initialization. If there are no subscriptions that continuously read, that initialization is done every time a synchronous read is done.
Hey Friends. I am currently trying to write approximately 700 tags from FtView13 to an Logix Emulate 5000. I am using rslinx DDE/OPC to create an...
410
Hello All, I know it is possibile to access data from a PLC directly to excel using a OPC link through RSLinx...
1,777
Hello All, I am going to try and lay out my situation as good as I can. Scenario: We have sites in different location across US that's running...
2,970
Hey! In my previous queries on how to handle an OPC server like RSLinx in the ArchestrA IDE galaxy, I have succeeded and the answer was to just...
1,836
Hey everyone!. I would like to know how to use a third-party data server other than Wonderware, such as RSLinx server to integrate it into the...
1,594
