FactoryTalk View SE VBA _click event
phuz
Jun 2008
Mohnton, PA
1,046
Why can I not add a click event to a single polygon?
I right click and hit the VBA code, and it would normally create the click event, but it doesn't, so I manually added it based on the object's name, yet it fails to work.
It works fine on items that are grouped, but not single, ungrouped objects. Is this a bug or intentional design?
It is FTView. There are no bugs, only poorly implemented features.
Simple "Drawing Objects" cannot be defined as "VBA Controls", only "Type Info Extensions", so, as far as Rockwell is concerned, it is working as intended.
Wow, that's horrible. So in order to put vba behind a rectangle, I need to duplicate the rectangle, and group it.
Thanks Rockwell. :)
I'm creating an HMI that has a recipe with 288 data point. It has 3 pieces of data for 96 segments. I need help with VBA code to copy all 288...
166
Hi, Can someone guide me through how to use FactoryTalk SE VB script to open communication with SQL Server? which command I can use? Are there...
2,678
Hello group, I have been migrating a project from RSView 32 V7.6 to FactoryTalk View SE Local Station V12 over the last couple of days. All told...
1,011
For trend charts, I can use an ActiveX Calendar control to select a date on a trend using the following code where "Trend" is the name of the...
1,627
Anyone know how to change the mouse icon to something else using VBA? It looks like it can be done with VBA forms and based on the object the...
2,235
