A-B CompactLogix 1769-L30ER memory backup question
1769 CompactLogix Batteries
The 1769-L23x and 1769-L3x controllers come with one 1769-BA lithium battery.
The 1768 controllers and the CompactLogix 5370 controllers do not require a battery. The controller uses internal nonvolatile memory to store its program during shutdown. Energy that is stored in the system maintains controller power long enough to store the program to internal nonvolatile memory, but not the external CompactFlash card nor SD card respectively
Regards,
Garry
http://www.accautomation.ca
Battery-less Energy Storage Solution...
The CompactLogix 5370 controllers use an internal Energy Storage Module (ESM) to do what Garry has described.
Some more relevant information...
465521 - CompactLogix 5370 Controllers Battery-less Energy Storage Solution
Access Level: Everyone
468536 - CompactLogix Capacitor Backup
465520 - New CompactLogix 5370 controllers Power Up Sequence
502060 - RSLogix 5000 software list Battery as one of the minor faults for CompactLogix 5370 controllers
Access Level: TechConnect
Non TechConnectors...
For a project using a 5370 CompactLogix controller, RSLogix 5000 still lists "Battery" as a minor fault and this fault can still be triggered for these controllers. This fault (Type 10 Code 14) refers to an ESM fault rather than a Battery fault. It can be monitored by using a GSV to the FaultLog Object, Attribute MinorFaultBits, bit 10. Because the ESM is not replaceable, this fault would mean replacing the controller.
572844 - Major Fault Type 1 code 40 in a Logix 5000 controller
If you get a Major Fault: Type 1 Code 40 it is a Major Fault on power up. This means that the last time the controller was powered down the ESM failed to store the project to the internal NAND flash memory. It is most likely a hardware failure of the ESM and it is not charging or holding its stored energy.
The Minor Faults: Type 10 Code 12, 13, 14, 15 will all set the Battery Minor Fault and are an indication that there is an issue with the ESM.
The Major Fault will of course halt the processor, the Minor Faults will leave it running.
Regards,
George
Hello Friends I need to replace a Micrologix 1400 L32BWA with 1 1762-OB16. I had thought in a 1769-L30ER, 1 1769-IQ32 and 2 1769-OW16. But...
2,441
Hi guys. I have some problem.I want to use AB PLC Control YASKAWA servo motor through MP3300 EtherNet/IP Communication Module. Now I download...
2,178
Hi All~ I have a case (designed by my boss But he has left the company) Please refer to the attached picture...
2,408
Hi, I am Akash. I am currently working on a PLC upgrade project from micrologix 1500 type to compactlogix 1769LRP. I have migrated the whole...
5,452
Hello, I am having some issues telling my ASCII card to send out data. Right now I am using a Serial-USB and using hyper terminal to receive the...
2,207
