Conecting M221 to ATV312
alejandrovg
Nov 2015
CAI
Hello,
I'm trying to conect this devices with Modbus RTU using Somachine basic but I don't get any response. The speed, parity, bits and timeout are the same in both devices.
M221 configuration:
- speed: 19200 bps
- parity: even
- timeout (x100ms): 10
- adressing: master
ATV312 configuration:
- speed: 19200 bps
- format: 8E1 (8 data bits, parity even)
- adress: 1
What I am trying to do is to read one variable inside the ATV312, in this case 9004 is the Modbus direcction linked to the Type of ramp.
And this is the program,
Image link:http://oi66.tinypic.com/30tgt8y.jpg
I need some help with this, I don't know where I'm mistaking.
Hello,
M221 configuration:
- speed: 19200 bps
- parity: even
- adressing: master
- speed: 19200 bps
- adress: 1
I haven't used that controller but do use Schneider, it looks OK to me, one thing though, what is %S13 is that a time pulse ? I cant remember of the top of my head, you don't want to start another read unless you have the complete bit
I would always start by proving the slave has good comms by using a laptop with USB/RS485 adapter and modpoll or similar, this allows you to get the indexing etc. sorted, then you at least know which end you are looking for problems.
Hello, first of all thank you for your reply
%S13 is not a time pulse, its a contactor wich closes at the begining of the program and then it stays open, so I use it only to start up the program at the first cycle.
But your reply made me think that maybe the reading of the variable lasts more time than one cycle of the program does, so instead of %S13 I will try to use a manual contactor. Hope it was only that, I'll write here the results once I tried.
OK, I don't have the %S functions in my brain like some people.
I would use a manual trigger for now until you figure out what's happening, we hold off doing any comms for a good 5-10 seconds AFTER first scan to let all devices boot and sort themselves out
Stupid question, but is your wiring correct? Sometimes serial wiring can be confusing, though at least you're staying within Schneider, so that should help.
I would definitely start with manually triggering the messaging, so that you are not dealing with race conditions, or messages being sent before the other side is ready. Once you know your wiring and syntax is correct move on to automating the message sending.
Hello! finally it seems that was the mistake, the %S13 was too fast to read the variable.
I changed that and used a manual contactor (%I0.0) then the Memory Word %MW0 turned its value to 1361, the motor nominal speed.
Thank you all for your help!
Hello,
M221 configuration:
- speed: 19200 bps
- parity: even
- adressing: master
- speed: 19200 bps
- adress: 1
Hey, guy. I need your help. My deadline is coming. Do you have an email ?
You need to do what the original poster did and show what you've tried so far. No one is going to do your work for you.
In fact most of what you need is already in this thread.
Has anyone ever tried to connect an HMI to a Yaskawa A1000 VFD? If so, what HMI did you use and what communications protocol? I want to try to...
2,088
Looking for some help on the red lion side I was able to diver out all the port settings to get the hmi to talk to elc having the are-485 light to...
1,109
Hi i'm new to this forum, and not familiar with plc therms in English. So please write with this in mind. I will try to connect my labview...
2,282
Hi Dear all i am workinh with plc i have controlled a single bit of digital output module.now i want to on/off the tubelight using this bit please...
2,083
Hi, Is there anybody tried before to use the HMI-GWY module to conect a Siemens S7-212 with NS12? Well, i can configure the module HMI-GWY with...
2,321
