dlubs
I have been trying to update the firmware multiple times now and still no luck...help!
I have it connected on the network, I can see it fine but I get stopped in the same spot every time with Control Flash or RSLogix AutoFlash. Here is an error log.
03/02/12 14:24:17 [SUCCESS] Load Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
03/02/12 14:24:17 [SUCCESS] Initialize Driver: C:\Program Files (x86)\Common Files\Rockwell\AB_ASA.DLL
03/02/12 14:24:42 [SUCCESS] Device Identity: Path = RSLinx API!AB_ETHIP-1 16 13 49 57 50 46 49 54 56 46 49 48 46 53 48 0 1 0, Instance = 1,
VID=0x0001, PT=0x000E, PC=0x004D, Maj Rev=01, Min Rev=15, SN=0x405A19A6
03/02/12 14:24:49 [SUCCESS] Validate:
03/02/12 14:24:49 [SUCCESS] Authorization: Bypass cookie used.
Key: PN-82655
03/02/12 14:25:04 [SUCCESS] Load Script: C:\Program Files (x86)\ControlFLASH\0001\000E\004D\PN-82655.nvs
03/02/12 14:25:04 [SUCCESS] Program: Catalog Number = 1769-L32E/A LOGIX5332E, Serial Number = 405A19A6, Num Updates = 3, Size = 5453588 byte(s).
03/02/12 14:25:06 [SUCCESS] Update: Instance = 3, Size = 2045916 byte(s), Chunk Size = 128 byte(s), Major Rev = 255, Minor Rev = 255
03/02/12 14:27:18 [SUCCESS] Reset:
03/02/12 14:27:19 [SUCCESS] Update: Instance = 11, Size = 1834808 byte(s), Chunk Size = 256 byte(s), Major Rev = 0, Minor Rev = 0
03/02/12 14:27:22 [FAILURE] Transfer: Error #11006: Service cannot be performed while object is in current state.
GS=0x0C, ES=0x3002
03/02/12 14:29:44 [FAILURE] Transfer: File = C:\Program Files (x86)\ControlFLASH\0001\000E\004D\PN-82657.bin, Block = 324.
03/02/12 14:42:55 [FAILURE] Device Identity: Error #11010: Path to self invalid.
GS=0x01, ES=0x0318
03/02/12 14:43:14 [SUCCESS] Device Identity: Path = RSLinx API!AB_ETHIP-1 16 13 49 57 50 46 49 54 56 46 49 48 46 53 48 0 1 0, Instance = 1,
03/02/12 14:43:24 [SUCCESS] Validate:
03/02/12 14:43:24 [SUCCESS] Authorization: Bypass cookie used.
Key: PN-28742
03/02/12 14:43:36 [SUCCESS] Load Script: C:\Program Files (x86)\ControlFLASH\0001\000E\004D\PN-28742.nvs
03/02/12 14:43:36 [SUCCESS] Program: Catalog Number = 1769-L32E/A LOGIX5332E, Serial Number = 405A19A6, Num Updates = 3, Size = 5453136 byte(s).
03/02/12 14:43:37 [SUCCESS] Update: Instance = 3, Size = 2045464 byte(s), Chunk Size = 128 byte(s), Major Rev = 255, Minor Rev = 255
03/02/12 14:45:40 [SUCCESS] Reset:
03/02/12 14:45:40 [SUCCESS] Update: Instance = 11, Size = 1834808 byte(s), Chunk Size = 256 byte(s), Major Rev = 0, Minor Rev = 0
03/02/12 14:45:43 [FAILURE] Transfer: Error #11006: Service cannot be performed while object is in current state.
GS=0x0C, ES=0x3002
03/02/12 14:45:46 [FAILURE] Transfer: File = C:\Program Files (x86)\ControlFLASH\0001\000E\004D\PN-28744.bin, Block = 230.
Thank you in advance!
Key: PN-82655
GS=0x0C, ES=0x3002
GS=0x01, ES=0x0318
Key: PN-28742
GS=0x0C, ES=0x3002
