1792D Armor Block I/O unit
rbyrne
Aug 2005
Ontario
So I worked through a problem I had in trying to understand how output devices were linked via DeviceNet to the SLC-500 PLC that controls them. The system is a pneumatic assembly line.
I discovered that inputs and outputs were joined to 1792D modules. I have established how to monitor the state of inputs that are joined to the Armor Block, and also how they are mapped to the 1747-SDN DeviceNet scanner in the system.
I also know how the outputs are mapped in the scanner, but I don't know how to determine which outputs are controlled by which bits in the Armor Blocks output byte.
The Armor Block in question is a 4I/4O type (1792D-4BVT4D).
According to the manual for the block, bits 0 through 3 in the "consumed" byte are used to switch the outputs, but I am unable to view these bits in the parameter list for the block. (The byte in qestion does not show up in the list).
With RSNetwox open and setup to show my network, I right click the node whose outputs I know I am forcing on from the SLC500 - I have verified the node number by monitoring the inputs for the Armor Block.
I select "Monitor" to cycle through the parameters in real-time, then toggle the output in question via my SLC500 program. I do leave enough time for the monitoring cycle to go through all parameters before proceeding.
My problem is that I see nothing else in the list changing state when the outputs are toggled - are the output bits (in a consumed byte) accessed in some other way?
Thanks,
Richard Byrne.
Hi Folks, I'm trying to assist on a devicenet input module failure (1792D-16BVT0CD), the module has been replaced with another exactly...
1,372
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
114
Hi, I have installed a number of Armor powerflex drives. They are controlled from an L81ES controllogix. DLR is on a ENT2R. I keep getting the...
1,869
Hello all, is it possible to reset a faulted armor block thru the plc? I know I can reset the devicenet card, and some devices thru the PLC, but...
1,472
I am trying to find the EDS files for the following catalog numbers: 1769-L38ERMO Standard 1769-L38ERMOS Safety 1769-L36ERMO Standard...
3,432
