Accel Curve
Is that a velocity/rpm/other graph? I assume it is not an accel graph since the line goes to constant value that is not zero. How are you controlling the drive?
Y axis is rpm, X axis time. So accel to and remain at ex.500RPM. The decel would need to follow the same curve.
The drive is controlled by a control logix processor.
Depending on your process requirements and tolerance, one approach would be to use a timer in your ControlLogix processor to update the command speed according to the rpm versus time curve until it reaches the final speed.
Never played with the PCAM of PF755, but I know it is in the settings. Maybe a little reading of the manual will help.
put the setspeed above the maxspeed and set maxspeed to your value, now the system will try to accel what you want, however the accel will be stopped by the maxspeed.
No stranger to motion. Historically, always programmed MAM in either real units or % of planner values in axis configuration. Ran across someone...
1,472
I'm running a Kinetix 300 in Position mode from a ControlLogix PLC and am wondering how to increase the Acceleration and Deceleration. I've tried...
1,440
Ok heres what Ive got I set the accel time for 300 seconds I selected option accel/deccel 1 I have torque control set to DTC with a minimum...
2,308
I am trying to set up a Kinetix 300 to do position moves. I am controlling the drive with a Micrologix 1100 over Ethernet. I am looking for an...
2,818
I am trying to set up a Kinetix 300-Micrologix 1100 system. I have most of the bugs worked out but I am stuck on something. I am...
2,301
