Hi, I need some help reading the value of Channel 0 of a 1769-IF4 card.
The analog card is in slot 1. So the Input value should be: Local:1:I.Ch0Data. The card has been configured in RSLogix 5000.
What instruction should I use to retrieve this channel 0 value and converted to a real value. It will be between 4-20mA, so it will require decimal points. I was thinking of using the COP instruction, but I am not sure what data type the destination tag should be to accept numbers with decimal points.
The plc is L35E.
Thanks in advance.
The plc is L35E.
Thanks in advance.
