Best way to access S7-1200 web server remotely
DLMUK
Jun 2013
Southampton
311
Does anybody have a practical solution for accessing the webserver in an S7-1200 remotely?
My S7 is located on a piece of heavy lifting equipment (driving) so it is not possible to give it a wired internet or LAN connection. What I need to do is use a device with a 3G/4G connection which will provide a suitable connection back to a PC in an office so that I can access the webserver.
Just use an e WON or competitor equivalent. I haven't kept up with that product space, so the only one I know is **** (is this still censored?), but DDNS VPN boxes for machines are popping up all over the place.
EDIT: weird that this site still censors e WON, one of the mods must have had a really bad experience with it?
thanks
I'm actually going to a demo day where **** are showing their Netbiter which will hopefully do the trick. Just look at all options.
I think that's only a 2G device. At least in the US, no carrier would accept it any more. Dunno about status of 2G in other countries. If he wants a Siemens module, something like these might be more modern.
http://w3.siemens.com/mcms/industri...s/pages/modems-routers-ip-based-networks.aspx
They are 3G/4G cell modems, and can also hook into Sinema RC if he wants VPN capabilities.
Nope - doesn't allow connectivity to the web server.
I guess I haven't used the 3G varieties, but I could have sworn they supported NAPT, which would allow that. You just need to access it over a different port number: 8080 is commonly used instead of port 80 for http. This does assume you have a static IP address from your wireless provider.
If dynamic IP, then you need a rendezvous server like Sinema RC.
Hello colleagues Anybody knows, what could be the best or a better option to bring with you when you are in service at factory to connect via...
287
Hi all, We are looking for the best practices when it comes to maintenance technicians having online access to our PLC's. We would like to give...
1,170
Dear all, Hope you are well, I want you help to select best device to perform remote access on remote control logix chassis.I choose between...
2,401
Hello, Can someone tell me the most economical/best software and hardware I need to put my 4 networked DH+ SLC 5/04's program and tags on the...
3,698
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
591
