Check if file exists in VBscript (WinCC Flex)
userxyz
May 2002
any
2,768
What do I need:
When They want to do an Import, this is called:
Code:
DeleteDataRecordMemory hmiFlashMemory, hmiOff, hmiOn, SmartTags("PERS_REC_MEMORY_CLEAR")
If Err.Number <> 0 Then
	ShowSystemAlarm "Error #" & Err.Number & " " & Err.Description
	Err.Clear
	Exit Sub
End If
ImportDataRecords "\\pcg4\Shared\recs_PERSPROGRAMMA.csv", 0, hmiOverwriteAlways, hmiOn, SmartTags("IMPORT_PERS_STATUS")
	Err.Clear
	Exit Sub
End If
But now I want to check first if the csv file exists ==>> Try:
Code:
Dim f, fs, filename
Set f= CreateObject("filectl.file")
Set fs = CreateObject("filectl.filesystem")
filename="\\pcg4\Shared\recs_PERSPROGRAMMA.csv"
If fs.dir(filename) = "\\pcg4\Shared\recs_PERSPROGRAMMA.csv" Then
'IMPORT POSSIBLE
End If
Or is this the way to go:
If fs.dir(filename) = "" Then
'end
Else
'import
End If
Should this work or should it be written in an other way ?
Thanks in advance,
regards,
Combo
Hello all, I have a Controllogix 1756-L61 with some RIO. There are a couple of 1734-OB4E's that have gone bad. (no output voltage) My boss found...
1,109
Hello I am new here and new to PLC's, I wrote this program for a class that I am taking and my local tech school. The description is switch 7 will...
430
2,029
I'm trying to save a project as an L5X and I need to uncheck the "Encode Source Protected Content" checkbox, but it's grayed out. How do I get...
966
Hello. I have been working on my first plc project for a while now. I just ordered all the parts that I need and before I did that, I created the...
2,070
