SysIntegrator
Here's the scenario:
I have an L32E controller that I want to add to our plant network for the purposes of going online with it and trending data (RSLinx OPC server). Because it talks to some drive and IO units over ethernet and is our most critical system, I want to keep the network physically isolated (Vlans aren't an option). My solution is to use a NET-ENI and the serial port.
My question is what is the proper configuration on both the NET-ENI and the controller? I have not been able to see the controller succesfuly through the NET-ENI. I have the latest EDS files for RSLINX (already did this for a SLC). I have tried with and without compactlogix routing checked, I have changed the error correction to CRC, and I've tried manually and automatically setting baud rates on both.
I'm wondering if I should have Protocol DF1 Point to Point, and if my station address should be 1 or 0.
I'm not using this to communicate to any other controllers.
Thanks!
Thanks!
