Connect a 1794-AENT to a compactLogix, error 16#0203
Dark
Oct 2016
Quebec
Hi everyone!
I am trying to connect a Flex I/O with one 1794-OW8 to it to a CompactLogix 1769-L24ER via Ethernet.
It all went well except that after every 10 seconds I have the module red LED coming up for a scond and it say: Error: 16#0203 Connexion timed out.
Wonder what to look for?
I checked the box "Use Unicast connexion over EtherNet/IP", but even if I uncheck it, there's still a connexion timed out.
Thanks for your help!
Dark
Hi everyone!
Dark
HI ,
Can you please check revision of 1794-AENT( it will shown on RSLinx) then configure miss math with RSLogix5000 software
BR
I am trying to connect an AB Flex I/O Profibus Adapter to a Siemens TI-545 processor. I have configured the Profibus network in ComProfibus and...
7,433
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
60
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
36
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
72
357
