Control system design
Nov 2014
ulaanbaatar
I'm working at Power plant.
Our power station have 3 boilers and 3 turbines.
3 turbines are controlled by 2 redundant plc
and 3 boilers are controlled by 2 redundant plc
Then i don't make any sense why 3 boilers controlled by one system.
i thinks our system is being high risk.
because if boiler's redundant plcs will stop. our all boiler shut off.
i think 1 boiler should controlled by one individual system.
and boilers control should be independent.
i dont know what other industries control system design.
please help me to give advice.
You need to look up what a redundant PLC is, and this will answer your question
All your boilers are running from 1 PLC. The second PLC is the Backup.
If PLC 1 fails and stops running then all control and the process switches to the second Backup PLC and the system continues running.
You can then replace the bad PLC while all boilers continue to run with no down time.
It is about reducing risk and downtime.
Could you run with only 2 boilers? or only 2 turbines online? The redundant PLC system might be lower risk, given how unlikely it is for both to fail at the same time.
There are other things that can affect redundancy; communications network, power, I/O...
If you have unlimited money and time, sure make everything redundant. But it sounds like when your boiler system was created they wanted to only buy 2 PLCs instead of 3 (or 6 if they wanted redundancy). The redundant PLCs seem fine to me.
Assuming your redundant PLC system is going to work well, I would look at the comms network (Ethernet?) and power sources.
Make sure that the two PLCs use different Ethernet paths to anything critical
and they have different power sources.
Ex. what happens if the only Ethernet switch does down? same power supply for both PLCs?
This isn't a programming manual, it is a book on wastewater treatment and energy conservation. I cover a lot of process and mechanical issues as...
31
19,979
Hello guys, in one recent thread I have read about tranfer functions and ways of design controllers. In school we learned simple examples such as...
5,663
I have to develop the FDS for a project. Appreciate if any of you could post some samples of FDS developed by you or provide some tips as to what...
7,464
hey guys long time no see. Well I am through with kodak and now a road warrior with goldco industries. I have become interested in designing my...
6,534
Hello Guys, I have tried the programming but can't twist my mind to make it work correctly. I'm using S71200 and TIA Portal. My system has...
218
