Controlling Current of Welding Transformer
RZR
Mar 2011
Iraq
20
Hello,
A wire mesh welding machine has 8 welding transformer with 2 welding head per each transformer. This machine controlled by Mitsubishi FX2N-32MT PLC and Delta HMI. In the HMI screen the welding time and welding current can be increased/decreased by entering numbers. The current controlled by PLC analogue output and SCR. I tried to configure out how the SCR controlling the current but I couldn't as the drwaings not available. My question is any one know how SCR with the anlaogue output from PLC increasing and decreasing the current and how the SCR connected with the welding transformer. What confused me is only 5 SCR and 5 analogue chanel used while the machine has 8 transformers.
The controller is called a Phase Angle Controller. Works like a lamp dimmer. Input is 0-5, 0-10, or 4-20 mA. Not sure how the transformers are connected. If you have a 3 phase transformer, only 2 phases need to be controlled. The third phase is connected directly to the contactor.
Should be a weld controller/phase angle coontroller in there somewhere. Depending on the welder manufacturer, usual suspects for the weld controller will be Harms & Wende, tecna, schaltter or clifford.
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
120
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
518
I'm a Manufacturing Engineer with limited PLC experience and I am doing some research for our Controls Department. Does anyone have experience...
188
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,085
Hi All, I am facing one issue with the SEW MDX61B drive. Issue- I want to run a conveyor with this drive in two directions but it runs in...
350
