DF1 RS - Micrologix 1500 - Problem
You are correct that the Source ID is the DF1 address of the port.
I've connected to dozens of 1764-LRP's with the default DF1 communication settings, so I'm sure that having the Source ID be =1 on both ports is not a problem.
Actually, in most DF1 full duplex point-to-point connections the Source and Destination bytes are ignored.
The OP hasn't verified what his physical connection is between the USB/RS232 converter and the Channel 1 port. My guess is that it's not a proper null-modem cable.
If I was going to recommend anything, I'd choose 19200 baud instead of 38400. 38400 works fine on the MicroLogix but it's marginal for some other interfaces.
Both ports are set-up exactly the same. Check the cable you are using for that side port. It should be a null-modem cable. (see pdf below for the cable pin-out 1747-CP3)
To compare two different programs open RsLogix then click on tools then click on compare.
Hello Mickey, i took your drawings and solder my own cable, first hit it started communicating between linx and Micro 1500 LRP. Thanx for putting it on the Here. i was getting close to buy a Bradly cable as i thought channel 1 would never work!! Cheers again.
You're welcome.
And welcome to the forum.
Hi to all, Unfortunatelly I can not provide any help with PLC but will do on some other forum for microcontrolers. I need help with PLC to panel...
1,636
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
139
Hi, I have a Micrologix 1200 that needs to be replaced (retrofited) and since the 1200 serie is not available anywhere I have to choose between...
4,735
Guys, need help. How am I going to use this MSG instruction in RS Logix 500 to communicate in PLX51-df1-eni router. I already configured the...
2,213
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,659
