DirectSOFT 5 HELP PLEASE
sonofsiemen
Jan 2009
Tennessee
22
I am creating a program that will end up flashing a light when a switch(input) is in a certain position and stop flashing when the switch(input) is in another position. I am already monitoring the switch(input), which is X1. My question is, how can i flash a light on and off???? By using a timer???? Or how do i go about this? Thanks for all the help!!!
I bellieve there is a one second on/off pulse bit built into the PLC, one of the SP bits I beileve. I don't have a manual handy, but if you call tech support they can give you the answer in a jiffy.
Sp4???
I am kindly new to this... what is the SP4 and how do I go about including it in my program to control the light? Thanks again! I am using a DL06 PLC too if that helps any.
What is the SP4, and how do I go about including it in my program to control the light?
SonofSiemen,
SP4 is actually one of the Special Relays (not just a contact). In other words, it is a relay output that is controlled by one of the PLC internal clock bits. You should use it just like any other internal relay.
SonofSiemen,
| SP4 A CERTAIN INPUT FLASHER |
|---| |-----------| |------------(L1)-----|
All, I have a program that I am adding the counter on Rung 83 (see attached). The reset logic is exactly the same as on rung 84, but I can't seem...
3,974
I'm hurting here and really need help. I have an old machine running a AutomationDirect PLC 405. I have a data collection system that is...
1,738
Hey All, I got an older piece of equipment here, controls done with an Automation Direct 06 plc (OEM is long gone). I'm trying to piece together...
2,388
Hey all, I have this old code am trying to convert. Never worked with this PLC before. The 2 rungs are attached. What is happening here? What are...
5,132
Hello There's a machine that im working on where the operator inputs a number on the touchscreen, the machine makes that number of parts and...
2,205
