Emerson ROC 800 flow computer question...
timothy585
Supporting Member
Apr 2021
Cajun Country
47
Anyone happen to be familiar with ROC 800 flow computer hardware? I'm new to the ROCLINK 800 programming software and I have a quick question.
I'm working on some small land LACT packages and I want to simulate the oil tank level so I can test the LACT's start-stop sequencing. I prefer not to wait an hour for the tank to draw down enough to go through a real cycle.
I'm sure there is a way to force the softpoint tank level value that is coming in via MODBUS from a TotalFlow. I just can't seem to find a way to overwrite the live value temporarily for testing purposes. It must be in the ROCLINK 800 software somewhere...I just cant find it.
Any input is appreciated.
Thanks.
Without knowing a lot about Emerson ROC specifically, I can think of a few ways to do this, but it would be useful to have some more information:
  • Do you want to do this on a live system with a physical TotalFlow device providing data from a physical tank?
    • No my problem, but I would hope you have considered the safety aspects of overwriting that value, and if it's not a trivial issue then asked at least one other person to do the same
  • Is the TotalFlow device a Modbus master or slave?
  • Is this Modbus TCP or Modbus RTU?
    • Can you disconnnect the Modbus connection to the TotalFlow device
  • Constraints:
    • How free a hand do you have with the ROC 800 program?
    • Do you have experience and/or confidence in modifying an ROC 800 program?
    • Do you want to do this without changing any code in the ROC?
      • Or can a minimal change be made?
      • Do you have a link to a programming manual?
      • Do you have the Emerson ROC programming software connected to the ROC 800 device? If yes,
      • Can you monitor live values in near-real time?
      • Does the programming software have a "Force" feature?
    • Will this test be part of a an ongoing maintenance schedule, or is it a one-time event (e.g. commissioning)?
    • Do you have a spare ROC 800 that could load the program in the operational ROC 800?
That's just a start. The answer may be simple, or it may be complex.
Does anyone know if it is possible to create a help file that would, when a user presses F1, bring up a custom help (that I made) about my...
120
Two questions for GE/Emerson e.g. PACSystemsRX3i (CPE330): 1. Is it possible to use 2D arrays inside a function as a local member? (I can only...
104
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
144
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
201
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
1,014
