Encoder Omron R88M-H50030 Servo Motor
emunoz
Jun 2007
Caracas
20
Good Morning:
Our company as a Miic Tube bender, dated 1991, which has several Omron Servo Motors. One of these, a R88M-H50030, 500 watt unit has a damaged encoder. The encoder has a number on it, R2B20Z019.
We have contacted Miic America, they say that the motor is obsolete, Omron US says that they did not sell these motors individually.
We asked Miic for a replacement and they say that it would require to adapt a another motor and change the Servo drive.
Does anybody have an idea where I can get an encoder for this unit ? Any suggestion will be appreciated.
Regards,
emunoz
Good Morning:
Regards,
emunoz
Pictures attached
We sent the Motor to a repair shop in US, where they determined that the encoder could not be repaired. Fortunately they found a used motor in E-bay, and they will use it to repair our motor.
Are there different alternatives to E-bay when buying used or obsolete parts for Servo Motors and PLC's ?
Good Afternoon:
We received the repaired Omron Motor, but now we are getting a "Er Ed" error code from the HS 22 Omron Servo Driver, which is not listed in the HS 22 manual.
Any suggestions ?
I am providing 24 volts on encoder input but getting the 24 volts on encoder output.The output voltage is not changing,so I want to ask what will...
2,360
Dear all PLC's master, I'm trying to connect CPM1A to rotary encoder (Omron E6B2) using PRV with this code (0 0 DM100), but i can't read the...
6,183
Hi All, Need some help regarding MicroLogix 1400 HSC, Can I use Omron Encoder : E6B2-CWZ6C 600P/R... I badly need help.. Thank you very...
4,350
hi i am a beginner, can any one help me to use encoder or a proximity counter to calculate the positioning of belts.
6,667
Help needed, Is there anyone who ever write code for OMRON Rotary Encoder with MicroChip's PIC16Fxxx series. I'm seriously needed. Thompson Soe...
3,462
