Exporting tags from RS5000 to FT ME
Jan 2010
right here!
25
How do I export my tags from an RS Logix 5000 project so that I can load them into a Factory Talk ME project and reference them while offline?
I see within Factory Edition that there is an option to import database tags from an RS Logix 5000 file with a file type of "EAS". The only file types I can see that can be created from Exporting in RS Logix 5000 is CSV or TXT.
Do I need to create an EAS from RS Logix, or can I import CSV files somewhere in FT?
Thanks,
Going from memory and I only did this once a while back but in the communication section/tab in ME you can place a link to your offline file.
I think then you will be able to do a direct reference to the tags if you like instead of creating HMI tags.
Hope this helps.
Hi all - is there a way to export the tag values using RS5000 V15.01. I have tried the export to csv but it didn't bring the tag values which is...
5,120
I am very familiar with Studio 5000 PLC programming. And I'm very familiar with C-More HMI programming. But this is my first time using a C-More...
343
Can anyone tell me how to export tags from PC Worx to a .csv file?
336
Hi I'm new in this forum my name is Alejandro, I'm currently working in maintenance department in a Die Casting Company, I'd like to get some...
1,406
I need to pull analog data from an SLC 504 processor into Wonderware so it the values are graphed. Any details on how to export tags from 500 and...
1,870
