How do I install Siemens COM ET200?
Jul 2009
Derby
Hello,
We have a customer with obsolete S5 Profibus hardware who needs to re-program the Profibus network but does not have the tools necessary. We have established that he needs COM ET200 and I downloaded the installation files for both version 4.1 and 4.2 from the web. Unfortunately, they do not come with any installation instructions. I have tried moving the files to the S5_Home directory and then try to access them through the Change > Others menu option in S5, but all I get is the DOS window hanging with a blank screen and not opening the program. Any help would be very gratefully received. Attached is a screen dump of the ET200 installation files I have. I am running S5 v7.23 on a Siemens Field PG with Windows XP SP3 operating system.
The Install.bat file should do the trick. open a comand prompt window, navigate the directory with the installation files then type "install" followed by enter.
If you intend to reprogram an IM308B then you'll need the ability to re-program the Eprom - Your PG may or may not have this feature. If you intend to reprogram an IM308C then you might have more joy using Com Profibus V5.1
Nick
Hi all. I installed a single analog input signal board on my Siemens 1200 controller. I connected a 4-20 mA signal from a rtd to 4-20...
2,462
Hi! I'm currently installing a long list of software on my new laptop, along with my colleague who's installing the same list on his. So far I've...
1,862
** First post ** Hi All, I've just joined a new company and I've been tasked with supporting a lot of old installations as well as developing...
20
3,618
I am setting up Siemens Step 7 TIA Portal on a laptop for the first time. Is there any tips or tricks that will keep a ton of extra process from...
12,759
Hello all. I tried installing the Siemens MicroWin 4.0.0.81 demo on my Dell Latitude D630 with XP SP3. The install bombed before it completed...
5,110
