HSC problem in delta plc
May 2018
Sholapur, maharashtra, india
I am trying a real simple program here. I've give DPLSY instruction to Y0 and made a wire connection so that the pulses at y0 output are reverted to x0 input. I am counting the the pulses at both output y0 and inp x0.
If I use a normal counter then it's giving accurate values, but when I use a high speed counter c235 for measuring input pulses at x0 it is giving a lot higher value than actual pulses.
I am using a low frequency of 20Hz for trial purpose. What can be the issue?
Is the output a relay or transistor (solid state)? If it is a relay it may be counting all the the bounces as well.
Just a thought,
Regards,
It is relay.
if it is counting those flickers or bounces, then it should be counted by both the counters isn't it?
Ive used two counters to measure x0 pulses.
one is arbitrary counter and another is dedicated for x0 pulses only.
High speed counter inputs have quicker response time, so will see contact bounce whereas normal inputs will have some form of filtering that will reduce seeing contact bounces.
Alan
I have programmed a cut-to-length system on ML1400 which I am simulating with a voltage controlled oscillator driving HSC:0. The program uses a...
1,548
Hello all, I have a strange problem with a high speed counter with a s7-1200. I have set up the hack input - it is a 2 channel a/b type which...
2,370
I am trying to use the HSC to monitor a pulse input from a flowmeter. I have an AB Micrologix 1400 1766-L32-BWAA and I am using RS Logix 500 to...
2,889
Hello OK what i have is a prince diecast machine with 4 encoders on the tie bars to measure the tie bar strech that give me the tonage of the...
3,716
I have a MICROLOGIX 1500 system which includes a HSC module. One of the counters is configured as a ring counter. When the counter overflow bit is...
2,904
