Integer not reading correctlt on HMI
...Sorry to take up your time.
Do not apologize for this. The more places in this forum that grounding is the issue the better for all concerned.
It's like hooking the lights for a boat trailer: when it didn't work as expected, how often was the issue not the ground?
I took out the timers for the fluctuation and it was not as bad but it was still there so i put the timers back in and now they are staying steady.
Again thank you for all the help.
Thanks for coming back and answering your own original question, you may feel a bit embarrassed (don't) about the outcome, but you have come back and supplied an answer, which may one day help someone else and also (if the memory holds up) given us all something to check if and when this happens to us.
People not coming back and confirming what fixed the question people ask on here is a pet peeve to many on here (or just me?) so thanks again for supplying the answer.
I am using RSLogix 500 to connect to a ML1400 PLC which is in turn connected to a Femto D4 Energy Meter. The energy meter is returning two...
3,126
Hi. I'm using a Modbus ProSoft where I basically map data to a big INT array. Example, where GX_I_63HPU is a REAL, MNETC.DATA.WriteData[200] an...
21
519
Good morning all, I'm integerating a device with a Rockwell PLC with V34 Studio 5000. The device reports error codes using a single integer to...
19
1,330
Ex If I Read from Integer file N7:0 N7:0 is an 8 point input card , input 0 and 2 are on , rest off When I look at : N7:0 -7 6 5 4 3 2 1 0 I...
783
The analog array has 16 individual bits and each bit is an alarm. SCADA is having issues getting the BIT bool value. However they can get the...
1,061
