Intouch Alarm DB Logger
mehtab.hassan
May 2014
lahore
Hello! I've a problem with Wonderware Intouch Alarm DB Logger Manger "Unable to create detail mode of tables"
I use Intouch 9.5 with Wondows XP-SP3.
Please advice me how can I resolve this issue?
Thanks & Regards.
Hassan
Thanks & Regards.
Hassan
Hassan, it looks like your alarm configuration is wrong. The sa password might have been changed. Run the configuration again to create the detail tables. Normally, it requires you know the sa password of the database.
Thanks for the reply the sa password is correct because during SQL installation i selected SQL and windows authentication mode and entered the sa password.
Can you connect to SQL with the sa password from Alarm DB Logger Manager using "Test Connection"?
Is the database "WWALMDB"?
You could try deleting the database and rebuilding it.
IS there a reason you want to use "Detailed" and not "Consolidated" for the "Logging Mode"?
Trying to use Alarm DB Logger to log alarms for history. I'm running Windows 7 and have SQL Server Express 2008 R2. When I try to configure the...
11,045
Hello All, I am using Intouch 9.5 for my application and I want to have configure Historical Alarms.I have installed SQL Express Edition for this...
14,745
Hi All, I'd like to know how to show 100 days of Alarm in the Alarm Summary in Aveva (Intouch) SCADA. I couldn't find any option like that in...
851
Hi. I'd like to have a filter on an Alarm Summary page where I could pick which of the 3 groups I created I want to display on the screen. I...
559
I found an older thread about fixing this issue, but the link to the technote was dead. I'm running InTouch 2014R2 with SQL 2012. When I try and...
1,310
