ISA P&ID Symbol confusion
dogleg43
Dec 2005
Indiana
520
My background has been primarily in the industrial/automotive area. Device abbreviations there while not exactly standardized between companies seem more straight-forward than ISA tags.
While I’m very familiar with P&ID tags for various flow & pressure transmitters, valves, etc. I have trouble with coming up with the proper tags for other common I/O. Please provide your input regarding applying ISA tags to various devices. For instance for a loop #’d 101 what should the tagnames be for PLC I/O:
A relay sensing UPS battery failure?
Motor over temperature sensor?
Motor seal failure (leaking water into it)
Alarm acknowledgement pushbutton
Control cabinet door is closed
A motor disconnect’s aux-contacts to sense if the disconnect is closed?
Finally, what is the latest version of ISA symbols (S5.1 the latest I can find)?
Thanks and looking forward to your responses.
Isa 5.1
I would number them to the foll0wing using the ISA 5.1 . Latest version ive seen is 2003...
Where yyy is your number running or associated
XSyyy - Misc Switch
TSHyyy - Temperature Switch
XSyyy - Misc Switch
HSyyy- Hans Switch
ZSyyy - Limit Switch
XSyyy - Misc Switch
XSyyy - Misc Switch
HSyyy- Hans Switch
Thanks RheinhardtP.
I was just over-complicating things as usual.
Greetings, Does anyone know the ISA (or other) designation for an ultrasonic sensor? ISA designates "US" for a utility station. The ultrasonic...
5,418
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
110
It's been a long time since I've had to think of P&ID tag nomenclature myself (and not gone along with some scheme devised by someone else). I've...
266
Dear Fellows; Good day. Here i share two images one is PLC Sweep Time control and Monitor Screen and the other one PID Control Screen. First i...
254
Does anyone have a library of the ISA standard process symbols in PNG, BMP or something that is importable into an HMI screen? I'm about to sit...
1,010
