Ladder + FBD
weldon
Oct 2013
houston
Is it possible to combine ladder and function block on RSLogix 5000? I can do ladder and FB but I have a code where analog and discrete signals are need to be on same rung.
Why not just do it all in FB. I do (almost) all my programming in FB. The AND and OR blocks are designed for booleans, the SEL block is another useful tool when a boolean is needed to select which analog to use in a calculation.
I have programmed whole plants without the need to resort to ladder logic. I find the end result is much more readable and easy to fault find program.
Mind you I haven't used RSLogix for a while (I mainly use Schneider UnityPro) so not sure about there implementation of the FB language.
Hi
In Ab the fb have to be a routine of there own as with sfc, ladder and st.
If you would like your fb on the same rung as your ladder you could create an
AOI. It looks like a fb and i explain to people that they are the same right or wrongly
Donnchadh
I'm not entirely sure I understand your problem -- you can have analog and discrete on the same rung with ladder. What exactly is it that you need to do??
Hello, So in RSLogix 5K I would be used to doing the following: 1. Double click the left of the rung, to bring the rung text editor, will be...
2,139
Hello, I'm currently working on an automation project with Allen Bradley RSLogix5000, FTView .... I have a problem with the analog outputs, I have...
1,914
Good day all. I would like to know if it is possible to change programming languages in RSLogix5000? For example, if a program is written using...
4,878
Hi, I want to do this in FBD in Unity PRO... how do I do that??? A B |---...
4,436
My dear fellows... please help the needy guy who want to convert ladder code for start up routine to FBD using some automated tool. Please...
5,013
