Mitsubishi PLCs
dshaffst
Apr 2024
Indianapolis, IN
I'm at a new job as the sole control engineer and trying to piece together where my predecessor left off. One machine I'm trying to get online with uses a Mitsubishi PLC. Up until now I've only gotten online with AB PLCs through RSLogix and Control Logix. Can those same programs also get online with a Mitsubishi PLC? I plugged directly into it via Ethernet and tried searching for it in RSLinx. I don't presently know for sure what the IP address is, but I searched RSWho through the list of PLCs in the plant and couldn't find any of them talking to suggest the unit I was physically connected to. Didn't know if Mitsubishi's used their own programming software.
It will depend on the processor GXWorks2 if the Q or FX0-3, FX5 & IQF I think need GXWorks3. If it was programmed in GXIEC or Works as an FBD Structured project without the original code it will return in ladder only with loads of high end tags & many conditional jumps, therer will be no comments either.
Does anyone has any idea to convert a RS422 Signal to RS485 2W ?
2,212
I have a Q03UDECPU but I have documentation/example for a Q03UDE(H). Is there are difference in the Ethernet blocks I must use? I am finding...
3,662
Hello, Will the Protocol format 1 or 4 support reading of ER (extended data registers) in Mitsubishi PLCs? Which protocol i have to implement to...
1,592
Hi guys! Recently in work I found myself in a position where I had to, almost, mindlessly change a heating current on some evaporating cell not...
4,809
I need to establish communication between Q02HCPU with QJ71E71 ethernet module, and Q2ASH with A1SJ71QE71N3-T ethernet module. Do i need some kind...
3,145
