moving an array into a UTD
asterof
May 2007
Califonia
554
oops that would be a UDT or a UTD
CSF_Array1 has four elements of Real
I have a UDT named Cost_SQFT
that has four elements
Cost_SQFT.cost1
Cost_SQFT.cost2
Cost_SQFT.cost3
Cost_SQFT.cost4
In one instruction I want to move
CSF_Array1[0] into Cost_SQFT.cost1
CSF_Array1[1] into Cost_SQFT.cost2
CSF_Array1[2] into Cost_SQFT.cost2
CSF_Array1[3] into Cost_SQFT.cost3
not use four move statements
can a COP CSF_Array1[0] > Cost_SQFT
length of 4 work
The length needs to be 1. The COP instruction length is used for the destination only. It will retrieve as many source elements as required to satisfy the destination. In your case, to fill 1 Cost_SQFT, 4 reals are required
The COP instruction will do the following:
CSF_Array1[0] ==> Cost_SQFT.cost1
CSF_Array1[1] ==> Cost_SQFT.cost2
CSF_Array1[2] ==> Cost_SQFT.cost3
CSF_Array1[3] ==> Cost_SQFT.cost4
This is what you want:
Hi All, I cannot seem to find a way to move a Boolean from an Arrays UDT into a DINT. I have an Array of 32 elements with a UDT data type of 4...
1,760
Hey all, This is more of a question of "can I do this more efficiently" rather than how do I do this... We collected a week's work of...
3,378
Hello all, The task at hand is a little tricky for me... a novice at best... This is all about an alarm and storing data into rs batch. I have...
5,449
Hey everyone. I am very new to using RSlogix and from the bit of searching this forum I've done, I found that everyone seems to be really helpful...
10,250
All, I am trying to reset timers when a Work Order change occurs. The Work Order comes in as a string and I am comparing it to a tag...
117
