No Data Updation Online In Data View
It's a SIEMENS 315-2DP CPU.The picture of DB shows like,
Hi there
As said to monitor the current value you need to press the 'glasses' button 6th from right side.
Or you can monitor the values in variable table.
In variable table just write the address db30.dbd0(AI_00) to monitor the data in this address.
Also select data type as decimal under 'display format' column.
But there also you need to press the 'glasses' button !!!!;-)
Hop I have not further confused you
May be you are not calling block in OB1 which is using this DB!!
You take it for granted the DB will show the values, there is something else which you are missing.
Hi, How to get data from multiple Mitsubishi Q03UDVCPU into master PLC Q03UDVCPU through QJ71E71-100 ?
54
When i load my client a[plication the following error is recorded in factorytalk view studio log Failed to load data server...
51
Hello, im quite new and still learning. I would like to ask is it possible for FATEK PLC to read data value more than 16k? I'm trying to move my...
82
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
152
Hi everyone, I have a 505 workshop program with PLC type of 555- 1106 and I was wondering how can I download the data documentation window as a...
257
