Panel-mounted keyboard & mouse holder
Maia
Sep 2004
Laguna
29
Hi guys,
Does anyone know where to find a panel-mounted keyboard and mouse holder. I'm looking for a holder/bracket that can be folded.I've tried searching in the internet but I didn't find one.
Thanks,
maia
Have you cheched the Advanteh website? They do a lot of industrial PCs.
http://www.electronickeyboards.com/Panel-mount-keyboard.html
http://www.panelmountpc.com/
http://www.stealthcomputer.com/peripherals_panelmount.htm
... if i can suggest something... think about touch screen or touch pad instead of mouse, mentioned advantech makes plenty touch-based things
i've experienced that application modified for touchscreen is safer than fully-working keyboard - on panels with Windows OS, it prevent users from OS corruption and other unsuitable things, but it depend on target of your project...
Check Rittal 4636.000 for example. This one mounts into panel door,
can be closed (and locked). There is another product (need to lookup part number and make, don't remember who was buying it) that is keyboar and mouse combo and mounts directly to door or panel side (see picture). it has lots of bolts sticking from the back side so it's good idea to cut them out with waterjet or cnc.
Hi, A customer wan't to show three IP cameras on three seperate displays. And he wan't them to be panel mounted into the control cabinet. I was...
2,686
I am having a discussion with an engineer and I say that the fuse should be mounted in a panel with the hinge on the bottom and he states that it...
2,791
Hi all - off topic but anyway...... We are looking at installing a new bottle line and I am curious to hear what the trend is with frequency...
4,755
Hi List, I have an application where I need to print out a small report (16 integer values) from an Allen-Bradley SLC 5/04 everyday at 0800. I...
4,788
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
83
