PanelView Plus Screensaver
An awesome coworker made a USB powered Arduino send a ‘left shift’ when an input (the red jumper) is made. It tested fine waking a PV+1000. I plan to add this with a smaller Nano board and a relay to a pending project. The PLC with plenty extra outputs is in the panel behind the HMI so installing won’t be much trouble.
On one PanelView project I applied a global variable to brightness. The PLC set it to 100% on System Start and 5% 15 seconds after System Stop. We didn't disable the screen saver because alarms appeared on the operator's PC but not on the HMI.
Thanks a lot guys! I just ended up using the current page for setting brightness. If it's on the dummy screensaver page, intensity = 5%. If it's on any other page, intensity = 100%.
We'll see how they like that for now.
Hi guys, In searching on this site and googling, I came across this thread http://www.plctalk.net/qanda/showthread.php?t=63546 which applies to...
3,816
I have a Panelview Plus with the screensaver enabled. The problem is that during a CIP process, the screensaver comes on and hides any alarm...
3,390
Wondering if anyone could help with this? I'm replacing OEM screensavers with my own (thanks to other posts in this forum). Without exception...
2,375
What would be the easiest way to download my own Screensaver, that the plant operators would enjoy, to a Panelview Plus. Thanks in Advance
3,303
Hello, When I setting the screensaver time on a Panelview 700 Plus to 5 minutes the follow happend: The screen are black and the Panelview...
3,454
