arkansascontrols
My latest project is a large scale retrofit on an existing CLX system, that has been in place for a number of years and has had MANY undocumented field modifications done over the years.
The system has multiple racks on CNET, with around 2200 I/O system wide.
To complicate issues, there are some field mods that were 'Rigged' to avoid making Programming changes, ie. a VFD replaced by a reversing contactor that originally had multiple fwd/rev speeds has outputs paralled into contactors to make it work 'as is'.
So I'm tasked with documenting the current system, and then I have a series of Hardware/programming changes to make.
Looking at a single remote panel for an example I have 11 contiguous inputs that were never wired (spares) on one card. If I XREF these in the program it indeed comes up dry. However if I simply select "Unused" from the Show Drop down they aren't there. In fact selecting "Unused" from the Show Combo, would indicate that ALL real-world I/O tags are in use.
There are WAYYYYY too many points to have to XREF every single one to determine usage, so how in the hell can I quickly build a list of unused I/O points?
I've spent the last 18 months doing a similar project on another plant with SLC500 platform so my CLX is a bit rusty.
Thanks for any help guys.
