Rs5000 mave
ericremp
Mar 2013
Nebraska
Hi all,
First post, I have an AB compact controller, L35E - 19. I am trying to smooth out a temperature input that has some inherant noise on it in a oven. The temp is just a display on a HMI screen, the heater element is run by an SCR on a analog signal so the temp is just a referance/visual.
I am trying to get a MAVE instruction to work in the function block. I set it for 15 data points, and a storage array for 15 points, my input is a DINT that is from a thermal couple input moved to the DINT tag, (I tried the t-couple input straight in also) I also made a 2 second timer to cyle the sample enable. For some reason I am not getting any data into the MAVE. I have checked: in, sample enabble, out. The MAVE tag is a moving average.
Seems like I have something silly wrong, I have not set one of these up and don't have any examples. I did try to follow a pdf example that is on this board with no luck. I could do it in the ladder with the FIFO stuff but want to figure this out.
Thanks, in advance, won't work on it again till tomorrow.
Well it was something silly, I rarely (pretty much never) have to add a routine or a ladder........I didn't have a JSR to the function block......so it works now. oooops.
Thanks for the pdf also that one is better than the what I had. Thanks for the help.
Don't feel bad. I think that's happened to all of us at one time, or another. ;)
I have recently made a career change after 25 years of being an electrician. I am officially a junior automation controls programmer. I recently...
396
Hi Guys, Hoping that someone could please confirm if the 1756-IF16/B is/isn't compatible with the 1756-L1 5550 processor(13.24). I'm sure I...
128
Hello, I need help making a logic modification to a RS Logix 5000 program. I can email the program and give plenty of insight to it plus I have...
2,233
Hey folks I was wondering how one puts shortcuts on the logic display for instructions. A few weeks back another programmer added them for me...
1,001
Hello, I'm struggling with getting an email to send using an eweb module on a controllogix system. Any chance I could get someone here to help?
1,891
