s7-212 with s7-300 series communication
zrawi
Mar 2004
Riga
41
S7-212 and S7-315..
How can I make these two CPU's to communicate with each other?
Is there any MPI connection possible or PROFIBUS connection or maybe some other type of connection?
I dont have much time left... :(
Please, please, please help!!
Thanks!
Hello zrawi;
Try the following item on Siemen's Support wenpage:
www4.ad.siemens.de, and search for Entry ID 747743;
it shows you the steps to set up MPi links between a S7-300/400 and a 2nd generation S7-200.
It is also possible to use a profibus module on the \S7-200, but a lot more expensive.
Hope this helps,
Daniel Chartier
Hi, I'm new to working with PLCs and I'm experiencing issues with my WAGO 750-8212 device. When I attempt to turn it on, the SYS LED (orange)...
959
Hi, I have an application where I need to us an RS232 printer to generate a ticket containing the following info: Date & Time Serial # User...
3,060
I have a Powerflex 753 that shows a fault code "212 safety jumper out" upon powerup of the vfd. The jumper is in place and there is the same fault...
5,223
Hello! I'm trying to get an I/O-island, Schneider Electric Advantys STB NIP 2212, to get an IP-address from a DHCP server by putting the switches...
7,888
Happy Monday to all, nothing like a good day with siemens portal !! Got a question regarding test mode and viewing a certain instance of a block...
1,781
