Saving Tag values in WinCC Flex 2005
Save TAGS to CSV file in WinCC Flex
  • WinCC Flex
    Votes: 2 66.7%
  • Siemens
    Votes: 1 33.3%
  • Total voters
  • Poll closed .
markw
Jun 2006
Peterborough
17
Can anyone help.
I am a novice user of WinCC Flex.
I have a project that i just want to log 60 Tag values into a CSV file once an hour.
I looked at using the log feature in WinCC Fex but the problem is that the log entry will populate 60 rows down the page instead of appearing accross the page.
I would like the values to appear in rows, eg
time1 TAG 1 TAG 2 TAG 3 ect.....
time2 TAG 1 TAG 2 TAG 3 ect.....
At the moment WinCC Flex shows
time1 TAG 1
time1 TAG 2
time2 TAG 3
time2 TAG 1
time3 TAG 2
time3 TAG 3
I guess I need to use the VBscript but was hoping someone may have an example.
Mark
Hi CharlesM
Thanks very much for the help, I will persevere with using the search engine.
Thanks again for the info.
Mark
Welcome
No problem at all. I think this is a common problem. I don't know why Siemens does it that way. It is fine as long as you only have one variable but it becomes a pain for any more than that.
Hello, During runtime I change values of some internal tags (i.e. F_CV of DO tags). And I want them to be saved when I switch runtime off, and...
5,478
I'm struggling with this...Times and Dates are always a mental-block for me. See picture. When I press SAVE, I want to take the current...
1,716
Hi everyone, I have to modify a program that has been running in the field for several weeks now. I would like to be able to save the tag data...
6,545
Is there a way to save the tag database in rslogix 500? I can see all the tags in the "excel address/symbol editor". I need to import it to...
2,069
Hi everyone, i have an issue with saving a changed value in an AOI, I am using L84E, Everytime i try to save my work to SD card, the program lost...
103
