Siemens S7 - Wincc to HMI Connection Error
macs_plc
Jan 2008
Nagercoil
120
Hi All...
I working with Siemens S7 PLC CPU315-2 DP & HMI OP 170B 6" Mono....
I can able to establish connection with PLC and i am able to see live data & also i can update the program....
but i cant able establish communication with the HMI...I guess i am missing something, I want to take the backup from HMI to WINCC and need to edit some screen, but whenever i click Device status (Project->transfer->options), the system pops up a message "check setting, connections etc"...
Please guide me to solve this issue...
Wincc version is 2008SP3
Regards
Macs
Is the HMI on profibus or Ethernet?
You are unlikely to be able to 'suck out' the HMI and be able to edit it because it is compiled before it is transferred.
You need to contact the person who supplied the HMI or check your company records for a backup or handover copy
You can use prosave to make a non-editable copy for backup purposes
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
351
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,121
Hi I'm trying to display a value on the HMI. In monitor mode on the code, I can see that value, but on the HMI , after downloading, it is...
987
I am working on a system with a siemens plc and HMI using TIA Portal V13 and WinCC. I wanted to remove to buttons from the HMI so the operator...
7,582
Tomorrow morning I have to use a rented Siemens PC to troubleshoot a Siemens HMI, programmed with WinCC, communicating to a couple of ABB drives...
10,187
