Simatic MPI with CPU / OP / PG
Mylo
Aug 2002
Dublin
135
Hi all,
Can any of our Siemens experts, clue me into how I can use my PG [Laptop] and my OP connected at the same time to the CPU on a MPI network?
Typically I use "Low" end S7-300 cpu's (i.e. with only 1 x connection port, 312,314 etc)
I obviously program with a PC adaptor connected into the Cpu and then remove to connect my OP, which is programmed via a serial download. form my PG. this mthod is Ok until I wish to monitor or modify the program online with the OP still attached. As I have to remove one or the other to achieve access.
I understand that Siemens do not have a MPI connector by part No. but they can use a profibus connector with a Piggy back. The way this was described to me was that I would use a 2 x Profibus connectors with cable and wire from the OP to the Cpu leaving this in place so I could "Plug" in to the MPI network without having to power off the units. However this costs a bit for this feature in connectors as I would have thought there would be a connector available for this. I don't mind having to power off either and plugging in a connector for commisioning that would allow me this, but I do not want the cost of leaving this in the machine every time I do it. Does anyone have an easier way. I am not that familar with Networking but can I make my own special lead / connector for this purpose.
Cheers
Mylo
Hi Mylo,
There is a connector with an aditional PG connection.
Internet document
Concerns products with the Catalog No.'s:
6ES7 972-0BA50-0XA0 PROFIBUS connector without PG socket
6ES7 972-0BB50-0XA0 PROFIBUS connector with PG socket
The new fast connect PROFIBUS connectors are now available. The insulation-
piercing technology enables a connection without having to strip the insu-
lation from the individual cores.
The following matched components are available for the fast connect techno-
logy:
- Fast connect connector with insulation piercing terminals,
(6ES7 972-0BA50-0XA0 without PG socket,
6ES7 972-0BB50-0XA0 with PG socket).
- Fast connect stripping tool for stripping the outer sheath, the individual
cores and the woven shield in one working step (6GK1 905-6AA01).
- Fast connect cables:
Fast connect standard cable (6XV1 830-0EH10), PVC sheath,
Fast connect robust cable (6XV1 830-0JH10), PUR sheath,
Fast connect trailing cable (6XV1 830-0BH10).
The fast connect system consists of connectors, cables and the stripping
tool and enables a quick, simple, user-friendly and safe installation.
Technical features of the connectors:
- Transmission rate up to 12 Mbaud.
- Sub-D connection on the device side and for additional PG socket.
- Vertical cable exit (same as for 6ES7 972-0BA(B)11-OXA0 connector).
- Integrated, color-coded terminating resistor with isolating function,
i.e. the ongoing bus is separated if the terminating resistor is switched
in (commissioning and service aid).
- Transparent cover for insulation-piercing contacts for an optical check
of contact making.
- Color identification of the terminal for cables A and B.
- Dimensions: 72 x 16 x 34 mm (L x W x D).
- Tension relief and shield connection via permanently attached cover.
- Core cross-sections: 0.25 to 0.35 sqmm, solid or flexible.
We particularly recommend its use for the following units:
- S7-300, S7-400, M7-300, IM 308C.
- ET 200M, ET 200B, ET 200L, ET 200S, ET 200U.
- CP 5431, CP 342-5, CP443-5 and RS 485 Repeater.
In general, the connector can be used wherever the 6ES7 972-0BA(B)11-0XA0
connector with screw-type terminals can also be used.
Your SIMATIC contact at your local Siemens office will answer any further
questions you may have.
Hi to all How many of you have had to replace a still working hmi with a different model in a system without having sources? Well, in my...
2,994
Hello! I'm trying to use one PG/PC as a gateway between a PLC and another PG/PC. I've been trying to follow this guide...
4,537
G'day, I was wondering if there is a solution to this problem I have. We have a production line with 15 Siemens PLC's. They vary from S7-313C...
3,515
Hi all, Does anyone know whether it is possible to Monitor/Program the PLC prog thru the OP3 to the S7-312. As in all connected and PC attached...
4,843
Hi all ! Here is equipment and Sycon-software for Simatic S7-MPI connections from PC's Ethernet connector. Cable must come from HUB or Switch or...
1,761
