Tag Values from Offline CLX Logic
amartins
May 2018
UK
Is there a way of exporting the tags and their values from an offline CLX logic? When you save the online project, it allows you to read all of the latest tag values and these can be viewed in the tag monitor when you are offline, is there a way of exporting all of these tags and values to excel or similar?
Thanks in advance
Have you looked through the RSLogix5000 Tools? There are some monitoring tools in there that might let you take a snapshot/ backup of them.
1. There is probably a way to parse it out of an exported L5K or L5X file, but that might get ugly.
2. Are you aware of the Data Preserve Download tool? I suspect that might solve the issue you are trying to work around.
3. If you manually copy/paste the tags from one open offline project to another, the current values come with.
Hi I have offline project and I want to copy a tag (the name and the vaule) to a online project is it posiable ?
1,471
I have an InTouch HMI that has PID parameters. I need to find what the PID values were in the past. I have backups from the past, but none...
48
5,664
Hello expert; I want to read the tag values from control logix plc over the WiFi connection. I did it by using Rs link OPC and successfully read...
1,181
I'm doing a routine that will average out a value based on a real-time measurement and create an alarm level X% higher than the value. This...
1,035
Hello, I am tasked to update a CompactLogix PLC program on a live system. The updates I need to make involve changing a user-defined data...
2,129
