Tia Portal How to retain values that are moved
thewalkerist
May 2021
Izmir
178
Hello everyone,
I am currently having a problem retaining values that i changed. Lets say today i ran my programme and i put my max motor speed to 100. Now this is good. As long as PLC doesnt close, this 100 value stays with me. But if i close the plc and open it again now that 100 became 0 again. And not only that everything resets which is not bizarre to be honest.
As you can see this is a problem though. Because lets say in the future i have more variables that needs to be retained(i will probably need to if i continue with my project :D). I will need to re-write my values everytime. Now i am looking for a way to save that 100 motor speed value so that after my plc closes and re-opens i dont have to change it again.
I thought of just changing my Max_Speed global memory bit with just 100 and move it immediately after the plc starts but if i do i have to change that value from the tia portal when i need to which is not ideal. Now i need to save that value but also be able to change it.
So lets say i use it for a month with 100=Max_Speed but after that month i want it to be 75. And after i change it it will always open as 75 whenever i open the plc instead of the usual 0
Either you can use a data block instead of marker memory... Or use marker memory but it should be within the retentive range which is being defined in the CPU configuration...
how can i define the retentive range and where?
And what do you mean by Data block? like normal data block? How can that work out?
This may seem like a basic question, but for some reason I have having real trouble deciphering the built in help content, as well as navigating...
5,502
Need TIA PORTAL 14.0 and i want to take a upload from plc. I can't download from anywhere. please give me download link. thanks
65
Hi! What is the way to convert the code from the Codesys code to the Tia Portal? Regards, WK
99
Hey Guys, I am using a siemens IPC with a siemens RFID setup (Part numbers below). I am looking to create a screen where I can add/remove users...
256
i am using profibus, i want to insert a hexadecimal word or byte to 4 byte like in the phot but i don't know how
169
