Transmitter Recommendation needed...
ganutenator
May 2002
kansas
1,440
I've read the threads for thermistors and hopefully get different results here w/o getting beat up too badly.
No, I can not persuade the customer into using RTDs or thermocouples.
My PLC is a Telemecanique M340.
My analog input card is an AMI 0410 4 channel isolated input card. It can accept a 4-20ma or 0-10v analog input.
My customer is using a 10k thermistor. (sorry no more info on that at this time)
Instead of just googling thermistor transmittors and buying one and hoping for the best, I thought I would ask you folk, if there are ones you have used that you are happy w/.
thanks-advance
cole-parmer?
I was thinking about ordering a Cole-Parmer EW-94771-10.
Anyone out there use this?
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
317
I need to protect some pressure transmitters from hot (120°C) oil. Does anyone have a favorite transmitter cooling element/standoff they use...
189
Hi ,when i check the 4-20 ma output from flowtransmitter with multimeter ,it can shows 4 ma , but when i check with process meter it only shows...
174
How fail safe mode in level transmitter works? customer requesting for fail safe mode when the transmitter got any issue or power loss on the...
1,025
Hi - I have an application where there is an option to use a PID loop embedded in the Transmitter to directly control (via 4-20mA output from the...
1,085
