Unable to copy the Block OB1
BoSChoW
Apr 2006
Nova Gorica
107
Hi all,
i wrote a simple program in OB1. I have my PLC in STOP mode and still i can't copy the block. I am desperate because i dont know what to do...
What should i do?
More info is needed:
  1. What brand and type of PLC are you talking about? I figure it's a Siemens one, but is it S5, S7-200 or S7-300/400?
  2. What software are you using? Please also mention the version, because with some problems it might be of importance.
  3. What type of communication are you using?
Kind regards,
Thank you all, i couldn't copy the block OB1 because i forgot to add this in SCL programing language...:
VAR_TEMP
INFO: ARRAY [0..19] OF BYTE;
W : BOOL;
END_VAR
I have an another question, does anyone know how to CALL a BLOCK in SCL programing language? Ok, with the standard blocks that are in the library is not a problem, but how do i insert my own blocks?
Sorry, but I have to step out on this one because I never use SCL. I only program in LAD and STL.
Good luck with your search!
Kind regards,
Hi, I have a PLC project backup from site which was created in PME 5.5 and now I am opening it in PME 8.6 but unable to create ST block since it...
1,795
Hi everyone I'm in a bit of a conundrum, I've been trying to get this HMI on our machine and I am unable to retrieve it. Device Delta Model...
1,010
Hello guys, Our working machine CPU I am trying to add one logic but when I am click download then warning ⚠️ message coming that Unable to...
1,423
As mentioned in another Thread, the wonderful new PC I've been given to work with has a habit of crashing at regular intervals. Now that I've got...
4,672
Recently we have purchased the Rosemount 752 remote indicator to replace with new one, Capability file for that FF Device is unable to import with...
46
