vga monitor keeps going to sleep
jimcav
Dec 2004
new jersey
229
i have a vga monitor that has to input one is a 15 pin high density sub d the other is a yellow composite video in. i am using the yellow video in for a camera. Is there something i could do to the 15 pin connector so it does not go to sleep?
jim cav
I would think that you'd need to contact the manufacturer of the monitor and provide them the details of the application in order to get an answer for this.
I'll take a stab. Sounds like he is trying to only use the composite input without the VGA input. You could try a VGA tester like this. http://www.cdadapter.com/vgaplus.htm
But, in doing this is seems you're going to be building something special that would be hard to maintain in the future. If your monitor is unique it will difficult to find a replacement. Instead I'd suggest you look for a composite video to VGA adapter. Then any computer monitor could be used instead of your special one. http://www.ramelectronics.net/audio...posite-video-to-vga/c10000-c11200-c11201.html
I would think that most of the modern flat screen monitor/TV units have a composite video in connector. Since they are made for video, they should not time out.
If your VGA monitor is old, it would be up to manufacturer to tell you what to do.
I little off-topic, but I have been coming up short on this. I am trying to find a touchscreen monitor(10"-12") that would be similar to a...
1,658
Does anybody know if it's possible to bring in an external video signal to a Panel PC running FactoryTalk View ME and bring up that signal in the...
1,063
The customer is looking for a large screen (>17") for displaying status information to see at some distance. We already have a Unitronics V1040...
5,387
I have a need to remotely locate a computer montior 100 feet from the CPU unit, don't know if I will get this or not... I've located a 100 feet...
6,385
We have a quad monitor setup with FT SE and we are utilizing a header screen at the top of every display. when we open a new page we abort the...
118
