FTV tag data, finding a tag
John Morris
Sep 2015
San Antonio
689
Hello all
Need some Help
Working with FTV 8.0, I have a stage view that represent 10 of 11 tanks. when I open the "Numeric Cursor Point Properties" sub panel "Connections", for value the tag Id is {#3.0}. I need to find this and point it to another location.
the reason I am confused a little is this global panel when open for tank two, can change the temp in CPU two. when open in tank 5 can change the temp in CPU 3
I moved tank four to skid one and now it will report to CPU2 But still writes the temp to CPU three..
Any suggestions
this is a global page. the top right is temp set point below that is hysteresis, below that run time in minutes and seconds.
Hysteresis = {#3:1}
Time, minutes={#2.2}
time seconds={#2.3}
This screen uses 'parameter lists' or 'parameter files'. Look them up in the help section.
The modification will be done in the associated list or file.
Bernie
Ok I read it, tells me how to create one, but not how to find one.
I went to the start screen editor and parameter files were checked. but no location was give. that was blank.
still lost but now i know about parameter lists and files,
thank you
Look at the button or control which calls this screen. The reference may be there. As a not I don't use parameter files, I just know of them. Sorry I can't help much further.
Good Lord, I feel like such an idiot.
I do this all the time in IDEC
Based on your recommendation Bernie. I took apart the "cluster". A "multi-state indicator", a "numeric display", and a clearly invisible "go to display button", .....with..... wait for it........ a G>D> parameter list. There's all that CPU 3 Sh.... stuff I've been looking for.....DUHHHH
{STAGE 4},{::[CPU3]N10},{::[CPU3]F30}
Now that that turd is completely polished, How does this {#3:0} relate to {STAGE 4},{::[CPU3]N10},{::[CPU3]F30}
Were are they connected.
I believe the '#3' in {#3:0} points to the 3rd parameter in your list.
So the #3 is '{::[CPU3F30} and it tacks on ':0' to that to make the final tag
{::[CPU3]F30:0}
ha haaaaa
your are VERY correct SIR.
The second {::[CPU3]N10} for the time in minutes and seconds is 2.2 and 2.3
I can not begin to tell you how relieve I am.
I started this thread on Friday, and it has stuck with me the whole weekend. ( kinda sucked )
Bernie.
I owe you a lunch Kind Sir.
Many Many thank you's
I am looking on that like freshly born cow o_O...Aaaaand of course..That is a parameter.. Thank you guys.. You also help me to refresh my memories..:)
I asked this question briefly in my previous post long post, I'm asking again here as the main point so it doesn't get buried. I am pretty new at...
1,516
I have spent multiple hours looking for a solution for the following problem. I have an HMI application that is meant to be installed at 3...
1,204
My SE project will end up being connected to two processors (1766-L32 & 1769-L33). Is there any way to let FTV Studio (SE) connect to both...
670
Wondering if anyone has seen this before and has a quick fix. Often times, when I'm modifying or creating a display, I'll copy/paste components...
1,053
Hello all, wondering if there's a simple way to detect when a tag's value has changed. I have some tags whose values get updated every so often...
1,652
